93 lx
    93 lx
    I'm going to start a work log thread so I can post all my useless information.
    And since I'm gathering parts for my turbo, this thread will ultimately be worthy.
    So... 1993 Protege LX with 53,000 miles as I bought it...
    ClubProtege
    Replaced:
    valve cover gasket, intake hose, spark plugs, air filter, dome light bulb
    got the a/c running perfectly
    Bought turbo goodies :D
    ClubProtege
      I went to the junkyard and got a new A/C switch (the old one was scratched up), white pull handles for the trunk and fuel cover (to replace the yellow ones), a front emblem, two door switches, and a stock radio.
      I replaced the radio and all of the speakers started working and now I have working buttons and tape player.
      I also replaced the emblems he painted black with other emblems (I have a ton). I put a metallic Protege/323 emblem on.
      I ordered new motor mounts and shifter bushings.
      ClubProtege
        Got an ultra-rare SILVER topped A code vaf. [emoji6] The silver topped A codes have a 12% better flow than the black A codes.
        Ring terminals arrived for redoing some grounding, shifter bushings are here, and fuel pump should be here this afternoon [emoji33]
        Accidentally bought 460cc injectors off eBay by making an offer that was accepted [emoji13]
        Not much left to buy
        Sent from my One M8 using Tapatalk
        ClubProtege
          LOL at silver top.... who made that
            Whoever was selling it on eBay!
            ClubProtege
              fancy fancy
                McMaster Carr "shifter bushings" installed and they are amazing. I was missing one bushing, so this made a world of difference.
                Got some grounding wires added.
                Went ahead and installed my 255lph fuel pump too.
                I need to hurry up and finish buying everything!
                ClubProtege
                  you are rocking out!!!! keep up the work!
                    No packages today. I don't know what to do.
                    ClubProtege
                      Hells ya looks good just with that little bit of miles do every thing professional I got lucky with mine had 200xxx miles one it and it was luckily taken care of and the rear protege 323 emblem is awesome trust me!
                      Sent from my SAMSUNG-SM-G870A using Tapatalk
                        The problem I've found with such low miles is that a lot of maintenance things haven't been done yet. I think I pulled the original spark plugs out.
                        It actually has a cheap paint job over the original tropical emerald metallic that is MORE tropical emerald metallic than before. It's nasty.... but I think I'll get the last laugh [emoji4]
                        ClubProtege
                          So I believe my only big parts left are:
                          Intercooler and piping
                          Bov
                          Turbo timer
                          Wideband o2
                          Gauges
                          For the intercooler piping, I'm trying to figure out where and what I need to tap off of it. I'm planning on a silicone coupler for the BOV. Where do I want to tie in the wastegate actuator? Anything else to tap off for?
                          ClubProtege
                            anxious to see what you do here
                              You are going to put turbo internal stock
                              Enviado desde mi GT-S5830M usando Tapatalk 2
