93 lx
    been a while since I've had an IHI car, but isn't the factory return hose molded with the curves built in?
    92 240SX: KA/T25, nerd mobile
      When I did my Garrett upgrade, I used a 90* angle out of the oil pan, angled upwords slightly. I then used a water line that was originally pre molded for a heater line, or intake manifold, etc. Not the best, since its not made for oil, but Ive yet to have to replace one.
      Mazda
      1988 Black 323 GT
      DOHC 16 VALVE TURBO
        Didn't get to do any work today.
        I'm ready to cut some more bumper and get my piping done.
        I need to attach the IAC and recirc valve piping to the main pipe.... I haven't found anyone around that can weld this aluminum.
        Sent from my One M8 using Tapatalk
        ClubProtege
            Originally posted by MazdaNoob View Post
            I got that.. I just need to get my intercooler higher to get my bumper back on
            ClubProtege
              Got my bumper/intercooler figured out. Dropped my radiator back in to get the intake piping situated... Definitely not gonna work. My stock radiator and fan are way too deep. Fiddlefarts. [emoji35]
              ClubProtege
                Nothing's fitting through there.
                ClubProtege
                  Ordered a Mishimoto slim fan.
                  Got the intercooler bolted up and the bumper to fit (surprisingly).
                  Ran the coolant line.
                  Finally got the intercooler piping situated. The straight couplers in my piping kit are horribly short. I need to find a couple more different couplers (longer and a 45).
                  I'm ready to for this to be donnnnnneeee
                  ClubProtege
                    Got half of my piping bolted up. I ended up cutting two pieces of piping and it fit better than I had planned.
                    Do you know hard it is to hold an aluminum pipe and sawzall it in two?[emoji37] ...rattled my brain.
                    I'm trying out the ATP quicktap for my wastegate. Got that put on.
                    Hopefully tomorrow I can get my bypass valve holes drilled and pipes attached. I'd like to get my gauges installed too.
                    My slim fan will be here Thursday and I can get my intake pipe situated.
                    ClubProtege
                      coming along!!!
                        Had a death in the family, so that put things on hold.
                        Got the new fan installed. That should save some room.
                        ClubProtege
                          About to try to crank it! I'm sure I'm gonna forget something...
                          Sent from my m8wl using Tapatalk
                          ClubProtege
                            You have more pic
                            Enviado desde mi GT-S5830M usando Tapatalk 2
                              Wow. It cranked first try
                              ClubProtege
                                Originally posted by mazda323bp View Post
                                You have more pic
                                What do you want pictures of?
                                ClubProtege
