Jackstand Racer Needing slicks and tune.
    Looking beautiful
    Sent from my 831C using Tapatalk
      One pretty much equal length tune to 6krpm manifold coming right up.
      Sent from my Nexus 4 using Tapatalk
        Tig welding is fun! Getting better by the tube. This is my first one.
          Looking good nice work!!
            Thx man! Here's number 2!
              Beautiful! What welder are you using?
                Um... Eastwood 200 I think.
                  Awesome man good job
                    Tbh the gas lens does all the work. I'm a noob.
                      estimated cost of materials for this manifold? how did you go about calculating the runner length?
                        About 400$ Canadian worth. Corki Bell derived formula from some website. I'll post if I can get to my PC. Need to calculate your camshaft and ports and such. And I mostly used a cut to size to size welding rod to play with and figure out where to pass the tubes. It's not perfect what so ever but it gets it pretty close.
                          interested to read said formula
                            Calculate Header Tube Length and Diameter - by Wallace Racing Home of Pontiac Powered Firebirds,Trans Ams,Pontiac Powered Dragsters,Pontiac Power Rules!
                            Here's the runner calculator.
                              And almost done. Wow the collector part and the last fitting was hell.
