Its not that fancy of a rotor system, 94-97 Honda Accords had a similar 'captured' rotor, as well as quite a few random Japanese cars from various years, so any decently regarded Japanese/import shop should be able to do them. I've never run shims/spacers other than the ones that were in the hub from the factory, and preload always seemed within range. Timken bearings are really tight in terms of their QC tolerances, I've never seen more than a thou in height from set after set, year after year. You probably are okay if the shim matches the range of shim sizes in the service manual.
edit: I always put the knuckle in the oven and bearings outer races in the freezer, they go together so easily then. Same with the inner bearings (oven), and hub (freezer). I've actually used a vice with enough temperature differential!
