Need Help, please!!!!
    I put a b6t in my 93 323. So far everything works except for the cel and starting. I'm not getting any fuel or spark. I hear the relay kicking, but still no spark or fuel. I have no idea what I am missing or overlooking. I would greatly appreciate any help/suggestions. Thank you.
    The list of causes is way too long with that small amount of info.
      What other info would you need? Give me ideas to check and I can give you more info.
        Well, trace the entire ignition system from the plugs on back, and check for volts at the injectors and trace all the way back.
        But it could just be a blown fuse. Or bent pins at the ECU. OR incorrect ballast for the injectors or bad grounds or any of a million other things that want to go wrong with an engine swap...
          Alright, well I'm not getting any spark at the coil and the fuel pump isn't kicking on.
            The fuses are fine, no bent ecu pins, all of my grounds appear to be fine. I swapped the vaf to one that came off a running car. I still have nothing.
