The 88' 323 Wagon build
    You got a lot of toys on your hands
    '88 GT
    '88 GTX
    '85 Toyota Cressida 5-Speed
    '88 323 GT
    '88 323 GTX
      The complete GT interior is now in the wagon which includes all the grey pieces to get rid of any signs of the old blue interior
      Time delayed interior lights
      Tilt steering
      Power mirrors
      And my favourite, power windows!!!
      1988 323 GT - B6T Powered
        looking nice!!!
          So I finished stripping the GT down and ready for the scrapyard, it's a very sad sight but here's the final pictures of my GT
          Since the wagon needs a windshield, I kept the one from the GT, we just cut the roof and under the cowl
          R.I.P.
          But now the wagon is back inside the garage, first time in months
          First order of business is the much needed brake job, 3 out 4 calipers were sticking, wheels bearing were making a hell of a lot of noise so it was easier to just change the entire front knuckles since the GT got a complete front brake job only a few months before I stopped driving it
          And the also good rear calipers and brand new ebrake cables
          When installing the rear calipers I inspected the rear wheel bearings and found metal shavings throughout the grease, so next up is to install new bearings
          In the meantime I've also installed the OBD2 port
            woo OBD port goodness!
            shame the gt saw its demise :/ but onto better things!
              I got the new wheel bearings installed and the next step is to fix an oil leak on the engine
              Turned out to be a cam seal and once I pulled the valve cover, I wasn't happy with what I found.... milky oil....
              So instead of replacing head gaskets, it'll be less work to replace the engine which I'm picking up another engine later today
              But I did get the battery fitted into the rear panel, just needs a tray to fasten it into place now
                RIP in GT!
                  Picked up the new engine last night to add to the pile lol
                  now to get it installed
                    nice collection there!!!
                      To hell with photobucket!!
                      I got the new engine installed, tweaked a few of the small things to do on the car, got the ECU mounted
                      Only thing left is a battery tray and windshield and this car is ready for the road
                      Here's a YouTube video of the car now
                        looks like it would be quite nice to drive. good to see it all buttoned up, wishing i had motivation to finish up my cars.
                        is there a tach solution? or do you have an aftermarket gauge somewhere? i was curious where you were shifting rpm wise
                          Pretty awesome ride[emoji469][emoji469]
                            Yes there is a solution to get the tach working
                            On my festiva I bought a Dakota Digital Tach convertor designed for engine swaps like this that change the number of cylinders so you can still use the stock tachometer
                            They're designed to work with pretty much any combo of gauge/# of cylinders and on my festiva I never had an issue in all the years I ran it, so it makes sense for me to buy another one for this car
                            Although they've certainly gone up in price since I last bought one lol
                              My to-do list at this point is to
                              - make a battery tray
                              -new serpentine belt (forgot to clearance the casting on oil pump for the different pulley setup and chewed up the belt lol)
                              -new windshield
                              -tach convertor
                              Then I think I'll be able to say it's 100% done
                                So I recently got a GoPro so I wanted to make a short video with it, it'll be awesome for when I take the wagon to the track
                                And testing out imgur for hosting pics
                                One more step finished, custom battery tray
                                The last mock up before paint
                                This is just to show the pieces I welded to the car that the tray bolts to
                                The tray itself
                                Bolted in place
                                Once the battery is in, I made this plate to slide into a slot in the front of the tray to lock down the battery
                                And the finished product, i plan on cleaning up the battery still since it's out in the open like that
