I looked online and it's too broad of an issue so I thought I'd check with some 323 guys to see if you guys can help me pinpoint the cause. As the title says oil in coolant but no coolant in oil. The car runs great so I wouldn't think a head gasket but idk. Any help is appreciated tia.
Oil in coolant but no coolant in oil?
I don't know what engine you have but check the engine oil cooler. Possible it's no good and causing the issue.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
