Anyone know if you can rebuild Dirtra 320 struts?
Dirtra 320
Yeah, it isn't a plug-n-play deal, either. You'll need to get your die grinder out and massage a groove out on the inside of the gland nut. The groove is what centers the original cartridge; it interferes with the Illuminas. No biggie. And then you'll need to get some 20mm (ID) nylon washers from amazon and use those as shims between the gland nut and the cartridge. I might have to take pics someday for posterity's sake.
I reached out to Tokico about rebuilding the two sets of Dirtras I have, and they said they weren't able to do the work anymore, nor have parts. If I knew the shock oil viscosity, I could probably have a circle track shock shop see what they could do with them, some of the biggest shops rebuild nearly anything.
