No and yes, mine stick out all bug-eyed pretty far. In looking at the reference pictures I was using, if you actually do it correctly, they shouldn't.
To Anyone Attempting The 97-02 Mirage Halo Swap...
why would the conversion be illegal? Here's what my state (WI) statue (Trans305) says about highlights "Every motor vehicle shall be equipped with a headlamp system meeting the specifications of the headlamp system with which the vehicle was originally manufactured." Wouldn't this conversion meet the original spec; I'd say it not only meets the spec it exceeds it. Or are you interpreting that to mean only the original light system counts?
I was thinking these were factory for the Mirage. It appears that they are not. That makes my argument that they meet FMVSS a tougher sell. BTW, the FMVSS state that that when the switch is the the high beam position only the high beams can be on and lows only in the low beam position. There is an exception, but i did not dig far enough to find out if it would apply in this case.
Originally posted by Rivet View PostI was thinking these were factory for the Mirage. It appears that they are not. That makes my argument that they meet FMVSS a tougher sell. BTW, the FMVSS state that that when the switch is the the high beam position only the high beams can be on and lows only in the low beam position. There is an exception, but i did not dig far enough to find out if it would apply in this case.Manual EVERYTHING...
