Rear Wheel Bearing Replacement Question w\ Pictures
    Guys - On my daily driven 1988 Mazda 323 GT (245,000 miles), I recently replaced the rear wheel bearings - both sides. It went smoothly and one side is perfect while the right is certainly more audible at low speeds and when loaded like taking a corner quickly.
    I decided to dismantle everything tonight and I discovered that the spindle had "burn" marks on the surface and also on the bearing as well. The spindle is fortunately not damaged and I am positive I can take some sand paper to remove the burn / friction marks. I would appreciate any thoughts and advice as to why this happened and hoping its a bearing tolerance issue? I ordered a new set of bearing tonight.
    Thanks!!
    Pictures:
    Yasin, I would replace the spindle and do the job only once.... reducing the spindle thickness will only further the issue. I would say you got your moneys worth out of those anyway.
      Thanks buddy!
      Do you know if these spindles are still available from Mazda?
