Klze swap bf
    Klze swap bf
    89 Mazda bf
    stuff needed to Start my build
    Toyota 3sgearbox
    KlG4 crankshaft pulley with 36-1trigger wheel for megasquirt
    Cam side mount bracket
    unfortunately i was unable to find an kl gearbox so i decided to do a Toyota gearbox conversion Click image for larger version
      Originally posted by sanjay19 View Post
      unfortunately i was unable to find an kl gearbox so i decided to do a Toyota gearbox conversion [ATTACH=CONFIG]67332[/ATTACH]
      Sweet. What mounts are you gonna use?
        custom mounts
          Got my 3sfe Flywheel back from the machine shop they redrill the Flywheel to fit the klze
            been a while since I came on the forum so here's a little update got the axle and starter .waiting on my fabricator to build the adapter plate
                welded flywheel!! thats extreme. keep up the progress
                  thank, did the template for adapter Saturday Click image for larger version
                    1/2" steal
ID:	1243375 out with the old Click image for larger version
ID:	1243376 in with the new
                        Did you make the adapter plate from that cardboard template? If so i would proceed with extreme caution... just a few thousandths error on the crank centerline and you can have a lot of clutch issues.
                          after making the plate we made sure the gearbox and crank aligned properly before boring the holes
                            pretty cool to see the toyota trans on the KL
                              update Click image for larger version
ID:	1245159Click image for larger version
ID:	1245160Click image for larger version
ID:	1245161Click image for larger version
ID:	1245163Click image for larger version
