Forced induction and black smoke/misfire
    1994 Ford Escort GT 1.8 VJ20 Turbo setup, Mazda 323 GTX stock intercooler setup, Bosch blow off valve, Y code airflow meter from a bp turbo escort, 330 cc injectors from a Mazda gtx, bp26 cams, bp26 ecu, stage 3 racing clutch, vaf downpipe, knock controller and knock sensor added in, 4 wire throttle body/position sensor added in. Stock O2 sensor.
    Puffing black smoke. I've tried adjusting the tps as good as I can with no success, I've tried playing with the distributor in diagnostic mode with a timing light, it seems as if I'm getting to much fuel and not enough air.
    Getting quite a bit of backfire and black smoke which means way to much fuel.
    Lacking power and then it drives fine up until the turbo kicks in then it spits and sputters and backfires as well has a hard time idling. Could it be because I have the same O2 sensor I ran when I was using my bp05 ecu? Do I need a different O2 sensor? Or could it be bad adjustment on tps or some other sensor causing me grief?
    Has anyone had this happen to them before or can relate and help me out? Been tinkering for two weeks with no success.
    Do you have a wideband?
    Sent from my SCH-I545 using Tapatalk
      No I don't
        what's your boost gauge doing when it misfires?
        also sounds like your air meter needs adjustment
          I actually haven't setup a boost gauge quite yet but yah I was thinking could be something with air meter also
            jfc are you serious?
              Hahaha yah dude I'm serious.
                Step 1: invest in a boost gauge
                There plenty of low cost boost gauges on ebay and amazon. Either glow shift or prosprt for the time being while you save up for something good. I liked the AEM Tru-boost controller, It has built in boost controller but they are $300.
                Step 2: get a wideband
                There are plenty of companys that make wideband 02. I have an innovated lc-1 and i love it.
                Step 3: Install said gauges
                Step 4: monitor said gauges
                Step 5: dont tiuch anything without said gauges
                With out a way to data log your fuel maps these two gauges will be your life line . If your boost is low you could increase it or tune the vafm by adjusting the mixture spring inside .
                1995 escort wagon gtr/holset
                1990 4wd pro - daily beater/monster car/mud buggy( sold)
                1993 323(sold)
                I'm buying parts i don't need, With money I don't have, To impress people I don't know.
                Some people are like slinkies. They're not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
                  assuming you used the egt harness ? did you repin at the ecu for the tps? also check your ecu-engine temp sensor
                    Yes I used my egt harness, yes rep in at the ecu for tps but I'm looking for proper clarification on that with posts. I think my vaf isn't reading because it's not setup right with the wiring ( not spliced in the right area) . I just changed my ecu engine temp sensor with no cure there so it's defiantly however I setup my vaf/tps wiring
                      gonna go ahead and assume you didn't install a boost gauge or wideband before changing more unnecessary ****.
                        Originally posted by atomicEGT View Post
                        [ATTACH=CONFIG]67486[/ATTACH]
                        10/10
                        1991 Protege LX 5MT, P/S, A/C, NOW Sun Roof!
                          Got her fixed up [emoji1305]
                            What was it that fixed your problem?
