That 140 is way too think, it'd be like a 70weight motor oil.
And I believe all the Lucas synths are GL5's so no they're both trash.
Also great picture Snowden.
Beater=/= Sleeper
You can run GL5 in the rear differential for sure. That's what GL5 oils are meant for... hypoid gears.
Not sure if the center diff has a separate oil reservoir from the trans or not. If so, you can probably run it there too... that's a hypoid gear also.
The one place you definitely don't want GL5 is inside the transmission itself. I recommend Redline MTL since you're in Canada.
... The first FWD BG with a Toyota E153 transmission conversion in the USA! Looking for BP x Toyota E153 adapter plates? PM me or contact me on Facebook: Riel Performance Parts
What is the problem with GL5?, it is the suggested oil for the later BG and Kia G-series trans. I could not find a spec for the BF gearboxes, so is it a problem for the BF or the g-series in general (I know a lot of them came from the factory with ATF). I just changed to royal purple 75w-140 in my kia box 323. I know it on the thickside, but I got the stuff dirt cheap. No problems so far and it shifts just fine.
