Hey guys. I have a Ford escort GT 1.8 with a similar setup as lots on the forums, been doing some reading around and seeing what others use and do with their setups. I have a few questions I'm hoping someone can answer for me.
My setup consists of
VJ20 turbo
GTX ecu
BP26 cams
Manual boost controller
GTX side mount intercooler setup
Bosch BOV to atmosphere
330CC injectors
Y code VAF
Corksport downpipe
4 wire tps
Knock controller and sensor
Now in theory I should be able to setup a decent amount of boost with the setup I have. Is there a fuel cut with the bp26 ecu that'll limit the boost I'm pushing?
Right now I'm able to put out 8 pounds boost (after install of manual boost controller) but that's all she manages to get to with no increase upon adjusting the boost controller so I assumed there is a cut somewhere they someone should know about.
What should I do in tuning aspects of the car? I've advanced the timing and tuned where I can, I still don't think she's set right, my budget isn't the best so I work with what I have at the moment
Unfortunately I don't have a wide band O2 sensor and no stand alone yet.
Where should I start on diagnosing this boost restriction or am I not setting something up right?
Thanks in advance for your patience with me
VJ20 turbo
GTX ecu
BP26 cams
330CC injectors
Y code VAF
Corksport downpipe
4 wire tps
