My '89 323 stalled tonight shortly after I had started the car, I was just driving out of the parking lot, then I stopped at a stop sign and when I pressed the gas it stalled, first time it's happened, although there have been other times when I press the gas shortly after starting it chokes as if it is going to shut off. What could be causing this? I'm guess it's a fuel issue...injectors? fuel pump?
engine cold, chokes when gas is pressed
