E153 and other big power parts
    R code vaf or A code vaf $75 each
    Gtr ecu $300
    Adapter plate for E153 $300
    ms1 v3.57 with pnp harness. Already has a BP turbo map on itClick image for larger version
    Will add more parts as I go though my stuff
    Is there any benefit to the A code or R code over the B code?
    "B" code VAFs are from RX-7 base
    "A" code VAFs are from RX-7 Turbo
    "R" code VAFs are from GTR BG
    Just different spring on the flapper door? Do they need to be tuned when installed?
      Heavier vaf spring Which help the vaf door to not slam open.
        What options does the ms1 v3.57 come with?
          It's just a ms1 extra with idle control.
            what turbo is the ms program for?
              Gt30 is what it was tuned for.
                Adapter plate sold
                  Ecu still available?
                    Yes it is
