Now I can't seem to find a definite answer for this, and seems like there is some confusion surrounding this.
Are the valves open under vacuum, or atmosphere?
I initially thought by bypassing the solenoid and just hooking the vacuum straight up to the actuator kept the butterfly valves open under vacuum. Or like some people have said they use zipties to "keep the valves open".
But I have also seen people mention that the valves are actually open all the time under atmospheric pressure. So that means the solenoid applies atmospheric to the actuator, not vacuum.
The latter supports my butt-dyno results, as it seems like I have far more low end torque when the vacuum is applied directly, bypassing the solenoid. When vacuum is completely removed from the actuator, my torque in the low end plummets.
Oh and FYI, this is a BP swap in a Ford Festiva, and haven't bothered to run the wire to the ecu for VICS yet. That's why I don't just let the ECU do its own thing and forget about it. But until then, I just want to figure out which is which.
