Results 1 to 15 of 15
Thread: Dropping rpm and stalling
  1. #1
    Livin in the past
    Join Date
    May 2011
    Location
    New Albany, IN
    Posts
    480
    Feedback Score
    4 (100%)
    My 91 323 will sometimes drop rpm really badly when i put it into nuetral to the point it will sometimes stall. It seems to only want to drop rpm either when I drive it for quite a while after the engine has been warmed up, and even then, it only drops rpm about 30% of the time. The other 70% it idles perfectly. I either have to heel toe the throttle while braking to keep the engine alive, or let it stall and start the car with the key. Outside of this, the engine runs perfectly normal. So what gives?
    Sent from my SCH-I545 using Tapatalk
  2. #2
    Likes AWD a bit too much jay's Avatar
    Join Date
    Jan 2006
    Location
    Snohomish, WA
    Posts
    4,220
    Feedback Score
    7 (100%)
    Disconnect the throttle position sensor and see how it reacts.
    http://www.clubprotege.com/forum/vbp...?do=view&g=110
  3. #3
    Livin in the past
    Join Date
    May 2011
    Location
    New Albany, IN
    Posts
    480
    Feedback Score
    4 (100%)
    Disconnecting the tps didn't really change anything. I did notice it only wants the drop rpm and stall when the radiator fan is on, and this morning it did idle high the entire time I was driving to work. It peaked at around 1900rpm at one point. I tried checking for air leaks, but didn't find any.
  4. #4
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    23,943
    Feedback Score
    79 (100%)
    how is your coolant level?
  5. #5
    Join Date
    Jan 2006
    Location
    Snohomish, WA
    Posts
    4,220
    Feedback Score
    7 (100%)
    You can hook an ohmeter up to the tps just to make sure it's OK, a smooth change in resistance is what is supposed to happen. if coolant level is OK, then we start looking at any and all wiring. Intermittent crap like this is such a pain in the ass...
    drop rpm and stall when rad fan is on.... hmmmm. How old is your battery? This seems unlikely as it prolly would not wanna crank over.
  6. #6
    Livin in the past
    Join Date
    May 2011
    Location
    New Albany, IN
    Posts
    480
    Feedback Score
    4 (100%)
    Coolant was a little low
  7. #7
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    23,943
    Feedback Score
    79 (100%)
    top it off & did that change anything?
  8. #8
    Livin in the past
    Join Date
    May 2011
    Location
    New Albany, IN
    Posts
    480
    Feedback Score
    4 (100%)
    No change lol. Just drove it at night, and it seems having the headlights on also drops the rpm. I'll check the battery tomorrow to see if it's good.
    Still doesn't explain the high idle when I'm driving for the first 20 to 30 minutes. It kinda acts like the throttle is sticking on sometimes. I'll look at it more thoroughly tomorrow
  9. #9
    Join Date
    Jan 2006
    Location
    Snohomish, WA
    Posts
    4,220
    Feedback Score
    7 (100%)
    Battery or alternator or regulator or some happy meal combo of all of the above, man. if you don't have enough volts, the car will draw more amps and that can do all manner of evil weirdness.
  10. #10
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    23,943
    Feedback Score
    79 (100%)
    ace alternators on ebay 140amp units..... never worry about power again
  11. #11
    Livin in the past
    Join Date
    May 2011
    Location
    New Albany, IN
    Posts
    480
    Feedback Score
    4 (100%)
    Gotcha lol. I'll look into it
  12. #12
    Registered User
    Join Date
    Jun 2013
    Location
    San francisco
    Posts
    14
    Feedback Score
    0
    Quote Originally Posted by FE3-323 View Post
    Direct plug and play replacement for the 323?
  13. #13
    Registered User Cloud_Strife's Avatar
    Join Date
    Jul 2015
    Location
    Brooksville, FL
    Posts
    346
    Feedback Score
    2 (100%)
    I would just warn that 3rd party alternators have horrible quality control for these chassis. alternators and compressors are by far the worst with my experience being a 75% fail rate.
    I would highly suggest you buy from a reputable company like Bosch or go through the dealer. Alternators are important and too much of a pain during install to decide cheap out on, in my opinion.
    Good luck
    1994 Protege LX 5MT /S, A/C, no Sun Roof.
  14. #14
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    23,943
    Feedback Score
    79 (100%)
    i've had amazing quality & even spoken with the owner. the ones from ACE alternators are higher quality than OEM IMHO
  15. #15
    1st Gen 1st Gen's Avatar
    Join Date
    Jan 2006
    Location
    Vancouver WA
    Posts
    1,734
    Feedback Score
    10 (100%)
    Quote Originally Posted by Cloud_Strife View Post
    Good luck
    I agree with this. Lot's of problems.
    1991 Protege LX with GTX swap, DD
    1990 4WD Protege with GTX swap, Project/garage decoration
    2006 Mazda 3 with 2.3, Her car
    1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
Thread Information
Users Browsing this Thread
Similar Threads
  1. Wondering at stalling and RPM levels (70 mph)
    By tradosaurus in forum General Discussion - BJ Chassis
    Last Post: 12-28-2011, 06:47 PM
  2. dropping pan without removing cs dp?
    By deathtrigga in forum Engine/Drivetrain - BG Chassis
    Last Post: 08-26-2009, 11:35 AM
  3. Replacing 4th and 5th gear without dropping the tranny?
    By dx92beater in forum Engine/Drivetrain - BG Chassis
    Last Post: 09-08-2008, 05:03 PM
  4. Dropping my 93
    By SleptWithURWife in forum Suspension/Brakes - BG Chassis
    Last Post: 07-30-2005, 01:03 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
