Results 1 to 6 of 6
Thread: Catalytic converter: when to replace the rear cat?
  1. #1
    Registered User vw.fe2o3's Avatar
    Join Date
    Mar 2008
    Location
    Atlanta, GA
    Posts
    131
    Feedback Score
    0
    Multiple emission related codes: p0037, p0421, and p0300.
    From a recent coil pack total failure coupled with 190k miles, I'm reasonably certain the front cat needs to be replaced now and I'll get moving on that. And at 190k, I think I'll go ahead and change the O2 sensors.
    Question is how do you know if the rear cat needs replacing? It doesn't seem to be monitored by anything, so how do you know?
    2002 Protege DX, 1974 VW Standard Beetle
  2. #2
    Village Idiot goldstar's Avatar
    Join Date
    Aug 2003
    Location
    Northern New Jersey
    Posts
    3,373
    Feedback Score
    0
    As you say, I don't believe the condition of the rear cat is monitored. I replaced mine when it started rattling loudly suggesting to me that it was breaking up inside and probably would no longer be emission legal.
    I don't know if this is helpful but it's the best that I can come up with in this regard.
    www.clubprotege.com/forum/showthread.php?57477
    Happy Motoring!
  3. #3
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    24,052
    Feedback Score
    79 (100%)
    the rear cat is not monitored, only the front. & by all means if you don't have emissions on your car just add a header & Oxygen sensor trick spacer.
  4. #4
    Join Date
    Mar 2008
    Location
    Atlanta, GA
    Posts
    131
    Feedback Score
    0
    Ha, unfortunately I do have to deal with emissions in the metro Atlanta area, so I'll have to have this sorted out by early August.
    No rattling detected thus far. I suppose I'll just replace the front unit and O2 sensors for now and hopefully that'll clear it all up. Looks like the Walker brand of cat, O2 sensors and gaskets will run $266 shipped from Rockauto.
  5. #5
    Join Date
    Mar 2008
    Location
    Atlanta, GA
    Posts
    131
    Feedback Score
    0
    Ok, mission accomplished. Pretty simple install, check engine light is gone and emission test passed this morning. All-in price just a hair over $300. Below is a list of parts and prices. I bought everything through Amazon with Prime free shipping. Prices were a few bucks lower even with shipping through a few other places, but I like the bulletproof return process including free shipping back if it comes to that with Amazon. I did not replace the rear cat.
    Walker 16220 Catalytic Converter: $192.88
    Walker 31595 Exhaust Gasket: $3.99
    Walker 31642 Gasket: $8.76
    Walker 250-24367 O2 Sensor: $38.78
    Walker 250-24629 O2 Sensor: $32.78
    Total price $293.83
    Additional parts needed:
    3 nuts, bolts and lock washers for the lower connection $2 or whatever at Home Depot. I think I used 1.5" bolts fed from the bottom upwards, nut on top.
    4 - 12oz Shocktop Belgian White $7 (prorated price of $10 six pack)
    O2 sensor removal tool - $0 Free tool loaner from Autozone.
    The cat I used does not accommodate the stock heat shield, but google images of that part and you'll see it already has them affixed to the outside.
  6. #6
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    24,052
    Feedback Score
    79 (100%)
    glad you passed emissions successfully!! & great list to top off the thread!
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 8
    Last Post: 07-23-2013, 02:53 AM
  2. Tips for replacing Catalytic Converter (Pre-Cat) BJ
    By Proplayer in forum Engine/Drivetrain - BJ Chassis
    Last Post: 10-28-2012, 05:26 AM
  3. Catalytic Converter
    By mp5wgn in forum Engine/Drivetrain - BJ Chassis
    Last Post: 07-08-2010, 11:11 AM
  4. 2000 ES...Want to replace rear cat...question on size
    By gordinho80 in forum General Discussion - BJ Chassis
    Last Post: 07-13-2006, 02:12 PM
  5. New catalytic converter
    By skullone in forum Engine/Drivetrain - BHA Chassis
    Last Post: 05-29-2005, 10:47 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
