COP on Megasquirt- Cyl 2 and 3 not firing
    Hi there,
    I'm in the process of upgrading my 1991 Ford Laser Tx3 fwd turbo BPT running a Stratified MS2 PnP ecu to Toyota Coil on Plugs in wasted spark mode, using the stock BP dizzy
    I can only get spark on cylinders 1 and 4, running firmware MS2/Extra 3.4.2
    Inside the ECU I have 2 wires from IGN A and B to spare connectors, as well as power and ground in a separate loom
    Using the spark test mode in TunerStudio, I can activate cylinders 2 and 3 fine.
    Any help would be greatly appreciated
    Regards,
    Matt
