Mazda gtr
    Mazda gtr
    323 gtr road legal track car
    Celica gt4 gear box and rear diff
    Forged motor
    Link G4
    Garret gt28
    Front mount
    Adjustable fuel pressure
    Electronic boost control
    Subbed
    Sent from my SCH-I545 using Tapatalk
      yes!!! more info on that intake plenum please. reminds me of a F series TB system
        Awesomesauce. I need to do a Celica swap as soon as I can get a garage to work in. Can't wait to see what else you've got up your sleeves.
        1990 Protege 4WD
        1 3 5
        2 4 R
          The plenum is home made in all honesty I think it is to big I have heard of the factory one supporting 500 bhp and mine is miles bigger than the factory one
            Yeah, the oem GTR intake is a very good bit o'kit and I wonder if there is any such thing as a better plenum, given the size of the ports and the displacement of the engine. Following this build with interest. You're using the same drivetrain and turbo as my rallycar but I bet you aren't required to put a 34mm retrictor on the coldside. Looking forward to dyno numbers....
