Results 1 to 5 of 5
Thread: Cooling fans no blow
  1. #1
    Registered User
    Join Date
    Jan 2018
    Location
    Austin
    Posts
    5
    Feedback Score
    0
    On Sis in law's 1998 protege with 1.5L DOHC engine. The fan does run when AC is on, but do not run otherwise, even when the engine is approaching over temperature.
    Sis in law replaced fan relay in fuse box on LH side of engine bay. There is +12 at one side of the relay coil, and +12 at common of relay throw. Energizing relay coil on bench throws relay.
    The engine coolant temperature sensor is replaced, before replacement engine temperature gauge did not move, now it warms up rapidly.
    This car does have two radiator/condenser cooling fans, I'm not sure which/both should run on engine temperature, and which/both should run on AC on.
    Thank you so much for any wisdom here. This is one of those jobs where compensation is good will/love, so we've got that going.
  2. #2
    Registered User
    Join Date
    Jan 2018
    Location
    Austin
    Posts
    5
    Feedback Score
    0
    Oops, my problem looks a lot like this one: http://www.clubprotege.com/forum/sho...ns-not-working
  3. #3
    Registered User
    Join Date
    Jan 2018
    Location
    Austin
    Posts
    5
    Feedback Score
    0
    Can anyone say if PCM error codes will indicate which if not both O2 sensors are fouled? It would be good to know which if not both are malfunctioning. Thanks in advance....!
  4. #4
    Registered User
    Join Date
    Jan 2018
    Location
    Austin
    Posts
    5
    Feedback Score
    0
    Update - after new water pump, new radiator, new T stat, new T sensor/sender, new hoses, car starts, temperature gauge reaches Hot very quickly. T stat opens only when gauge is reading H.
    Top tank is quite hot to touch, lower tank is cool to touch with fans running.
    Looks like gauge is reading high, car does not seem hot, with radiator cap off coolant flow is observed, no boiling over etc. Sender is AZ cheapie. Are there multiple sender applications for this car? Anyone had issues with T gauge reading high?
  5. #5
    Join Date
    Aug 2003
    Location
    Madison, Wisconsin
    Posts
    24,097
    Feedback Score
    79 (100%)
    i would get the right sender from the junkyard. or mazda OE
Thread Information
Users Browsing this Thread
Similar Threads
  1. Radiator Fans?
    By 96Pro-Tege in forum Engine/Drivetrain - BG Chassis
    Last Post: 10-05-2009, 06:35 AM
  2. Cooling fans are too HOT!
    By mikes_protege in forum General Discussion - BHA Chassis
    Last Post: 07-26-2009, 10:52 PM
  3. cooling fans not working
    By equality92168 in forum General Discussion - BHA Chassis
    Last Post: 12-05-2006, 12:05 PM
  4. Single and Dual Speed cooling fans
    By Ambassador in forum General Discussion - BG Chassis
    Last Post: 10-30-2004, 11:34 AM
  5. any Rise Against fans?
    By Marc93lx in forum Off-Topic
    Last Post: 08-17-2004, 11:14 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
