the lower bolt on the v6 alternator goes the other way, but that's minor & can easily be finagled from the inside of the fender. Its much worth it. the entire car runs better
I was out of town and just got back so I went out and put the old one back on (and swap in a good temporary battery) so I can make emissions and then go after the V-6 upgrade.
Nope my bad.
It’s not 66 amps...25amps the tech document said.
Sorry for the confusion guys.
But again should I upgrade the stock alternator?
When the fan is on rpm drops a bit and also windows are struggling. Gets worse when I have the aircon on. I have a deep cycle battery as well 550cca I think
Good brand fan! I love my mini spal
Yes upgrade the alternator.
Additionally. Rewire the fan on a new circuit with thicker guage wire and a relay for best results.
I might suggest also doing "the big 3" upgrade at the same time as the alternator itself.
Yes I love my spal!
I got a 140 amp from a V6 engine but I will need to fiddle with it to fit it but that’s fine.
I think will be enough and I will do the big 3 upgrade as well
As for the gauge wire what type/thickness?
as big as you can still fit into the fusebox. and as big as you can otherwise for the alt & for the starter
Alt/starter can be 0 guage i think the max you can cram into the OEM fusebox is 4guage but don't quote me
Hi buddy.
I managed to source a Bosch 110A alternator as the 140AMPS would have been too big and also I would have need to fiddle a lot with it and I don’t think it worth it.
I think the 110amps will be enough.
As for the cabling I am thinking of using 4 gauge all around but I don’t understand what you mean when you say to cram in the fuse box.
Also will I need a circuit breaker between battery and alternator and how many Amps? 120a is enough?
