my check engine lights been on so i got the code pulled and it was the 02 sensor.{free at autozone}all they had was an universal sensor for 18$,1 wire hookup.my 98 es has 4 wires.they said it would work.so i bought it cause an o.e sensor from the dealer or napa is 370$!!!can anyone tell me if i should splice into my wires or take it back for a refund?somebody has to know.
universal o2 sensor
02 SENSOR
AUTOZONE SOLD ME THE WRONG ONE,I TOOK IT BACK.THEY'RE FULL OF ****!ANYBODY KNOW WHERE I CAN GET A 4 WIRE 02 SENSOR BESIDES THE DEALER?(THEY'RE TAXING)OXGEN SENSORS.COM ONLY HAS ONE FOR THE 1.5 ENGINE.ALTHOUGH IT'S 4 WIRES I DON'T THINK IT'S THE SAME.OF COURSE I COULD BE WRONG.ANY HELP WOULD BE APPRECIATED.
Don't type in all caps.
You wanted an 18$ universal one, how good do you think it would be??
I paid 275$CDN for mine.
THe o2 sensor should work but its not the one that you needed, they gave you one that goes in the exhaust pipe,not the oe that goes in the exhaust manifoldLast edited by midnightblue97; 09-21-2003, 05:49 PM.Ryan The middle child is always ignored
BP powered 97LX Touring Edition
Vibrant strut tower brace, KVR front brake pads, Tungsram Megalicht H4 headlight bulbs, Phillips Halogen H3 foglight bulbs.... 91 GT rims w/ 195 60 14 Yokohomo Mirada GTX sport
You can try your luck at the junkyard. My front O2 sensor heating circut went bad and i replaced it with a junkyard unit. Now the CEL is gone. I confirmed that the new "old" sensor works as good as any other o2 sensor by connecting my OBDII scanner to the car.
The yard will charge you maybe a buck or two for the sensors. Get 2 or 3 so that you won't have to go back if one of them doesn't work. Just heat the sensors with a blow torch or over your gas stove until it's red hot to clean all the crap from it b4 u install it on ur car.
Btw, any 4 wire bosh O2 sensor will work fine for you as long as the connectors match. That means you can try sensors from 96 and 97 sephias too.
PS: Don't touch/soil the part of the sensor that goes inside your exhaust.
<a href=http://s87170394.onlinehome.us/><img src="http://s87170394.onlinehome.us/ente_anm.gif"></img></a>
