99/00 DX/LX to 99/00 ES Brake Caliper and Rotor Upgrade
    Check this thread:
    Clint/1999 "Sport20"
      lol, Neg you know Dave Potter did this first.....I got my Sport20 bumper too...next purchase is rear skirt then this upgrade...how 'bout www.car-part.com for new calipers
        actually, Dave went one step beyond and replaced his front brakes to Wilwood Big Brake Kit (13" rotors!!! )
        '04 Titanium RX-8
          Not before he already had done the ES swap first......
            Yeah, I know. I just posted this to help everyone else out.
              Would the upgrade be almost as good if I used parts from a from a wrecker??? I used to work at one so i get used stuff ultra cheep. Also...has anyone done a rear disk swap on a '00 SE??
              '00 Protege
              Stock
              '88 GMC half-ton
              Soon to be 400hp
                Parts are parts, I don't see why not assuming everything works correctly.
                Rear disc swaps on our cars are slightly hard, read TheMAN's FAQ and there's a list of all the EDM parts you will need.
                  i know this thread is old as crap, but was their noticiable stopping power???
                  .....HELLO MY NAME IS BEN...
                  186.08whp
                  225.94wtq
                  torque monster!!!!
                  dyno graph 8-10-and 12psi
                  blahblahblahblahblahblah
                    I could feel a noticeable difference....but then again my old brakes were ****ed (slider pins rusted shut)
                      I cleaned this thread up and opened it up again because there's useful information here.
                      Happy Motoring!
                        Do you have disc on the rears?
