99/00 DX/LX to 99/00 ES Brake Caliper and Rotor Upgrade
    Here's a list of all the part numbers you need to upgrade the front brakes on your 1999 or 2000 Protege from the tiny 9.3" rotors to the larger 10.2" rotors.
    (1) B26K-43-900 - Proportioning Valve
    (1) GAZR-33-99Z - Left Caliper
    (1) GAZR-33-98Z - Right Caliper
    (1) GCYD-33-23ZD - Brake Pad Set
    (2) BJ1Y-33-25X - Brake Rotor
    Everything is a direct swap.
    Pictured are one of the new calipers, both new rotors, brake bad set, and my one of my old OEM rotors.
    Clint/1999 "Sport20"
    Negatize.....awesome idea,Thanks!!
    Do you notice any issues that may be a concern when installing?
    Jeremy W
    '99 1.6L Protege
    JDM Clear corners/ Injen Intake/ AWR Motor Mounts/ CP Racing 4 point Strut Tower Brace/ CP Racing Lower Tie Bar/ Brullen Cat-Back Exhaust/ JDM Mazdaspeed Adjustable Struts/ Mazdaspeed B-Spec Springs/ Mazdaspeed Front & Rear Swaybars/ Mazdaspeed Trailing Links/ Goodridge Stainless Steel brake lines/ 16" Rota Racing Grids on Falken Azenis/ P5 Steering Wheel/ CG Lock/ Alpine 9833 Deck/ Focal Access 165A (fronts) and Fosgate 6x9 (rears)/ JL Audio 12W3 (sub)/ Zapco 650 Amp/ 1 Farad Cap connect with 2 gauge wire/ Clifford Alarm
      Not yet, I haven't swapped the brakes out yet. Waiting on my other caliper to come in, it's currently on backorder.
        price of upgrade?
          Let us know how things go.... I am thinking about doing this also.
            Using new parts, with my Mazda Racer Discount, approximately $500.
              Good thinking Clint. I would be all over this if I still had my 2000.
                www.mazdamotorsports.com
                not bad at all, i was expecting more
                  haha... I was expecting less... then again I am cheap.
                    $500 is not bad at all for brand new, OEM brake parts. Normally, I'd expect to pay that for one caliper, knowing some dealers.
                      try remanufactured calipers and generic OE replacement rotors from your local auto parts store if you're doing it on the cheap
                      '04 Titanium RX-8
                        Good idea Hank.
                          Install is done!
                          HOW TO:
                            Lets see with the wheels on.
                              Sounds like another project for me 2 start...nice pic.........
                              "mess with the mazda...... mess with the chick......."mazdachic"
                              I don't go looking for no trouble but somehow the trouble always finds me, Don't make me have you in the trauma center With your momma crying cause her only son is dying, She just don't know it's just your karma catching up cause I'm a Drama Setter
