fule filter
    fule filter
    any idea of where the fule filter is at and how harf it is to change?
    More Information
    firewall, follow the fuel lines from the fuel rail
    I found out how to beat a Honda! Just about anyway you can think of. Even in reverse. <- my buddy Mike: Haha, your Civic is a pile of vtech crap! Zoom-Zoom!
      thanx
      More Information
        You might need to remove the battery for more room. The hoses could also be a problem as they are somewhat hard to take off. Take your time and you should be fine.
        '91 LX
        '03 Mazdaspeed Protege #235
        Originally posted by pigeon
          while you are at it remove the intake. And the fuel filter is a real PITA!!! makes sure ou have time to monkey around. and i'll put money that your fuel lines have solidified. making it next to impossible to pull it off.
          Originally posted by goldstar
          A Protege driver named Brock
          So his engine he goosed
          With much too much boost,
            It really is a PITA! You don't have much room to work in and the hoses can be a bitch to get off. I found that if you twist the filter, it helps to break it free. I ended up having to crawl underneath my car to get the bottom line loose. Have fun!
            2013 Dodge Dart Aero
              you can do it in a couple hours...i didn't have much trouble just gettin the lines off.
                Originally posted by Protege Menace
                Where is it located on 1st gens?
                on my car we replaced it and it was dead center of the firewall.
                took some effort and small hands (andres) to get the bottom hose off, and then back onto the new filter. they couldnt have put it anywhere harder tog et at on my car >:0
                Its in the same place, on the firewall right behind and below the TB. And yeah, it takes small hands. Its easier to remove the intake and possibly the battery to make more room.
                  when i pulled off my fuel filter i had to cut the top line and replace it. once the top one is off the bottom one i found easiest to get to from underneath. but i have slightly smaller hands
                    Same thing I did, except I managed to get the top hose off. But the bottom one had to be removed from underneath.
                      I hate those clamps, is there a special tool for them?
                      2006 Mazda 3 hatchback manual
                        yeah needle nose plyers work very well
                        More Information
                          linesmen plyers are best, neetle nose slip off
                          No more protege, Mx-3 now...Only known BP powered Mx-3 in Nova Scotia
                            I like needle-nose Vice-Grips. They don't slip off.
                            David Avard
                            '90 Protege LX (STS-prepped)
                            '89 Civic Si (STS-prepped)
                            '02 Altima SE (14.164 @ 97.7mph stock)
                              A-ha! I was looking for those at Sears, though I couldn't find them.
