Ive Been reading alot lately on on all the BP SOHC, BP DOHC, BPT DOHC.
Lets start with a straight Bp Block.
You will Need the Forged Crankshaft out the BP DOHC, or BPT DOHC. 90-94
You will need the Forged Rods out of the BP DOHC, or BPT DOHC. 90-94
You will the Pistons "8.2:1 Compression Ratio" Out of a BP SOHC. 94-97
These Pistons have a story behind them its, pretty amazing.
Piston history.
Further, the pistons top ring groove area is reinforced with integrally cast nickel-based "metal foam". The nickel foam is produced by electroplating urethane foam, which is then melted away, leaving porous metal "foam". The foam ring is integrally cast in the piston by the squeeze-casting method. The metal reinforced, squeezed-cast piston with cooling channel was first adopted in Mazda's direct-injection diesel engine, whose pistons are subjected to extremely high thermal load during the combustion process. the metal reinforced piston is about 10 percent lighter as compared with an aluminium piston with Niresist top ring groove, and according to Mazda's testing has an extended piston life by threefold. The piston's skirt is also zinc-plated for improved wear resistance, and its inside is cooled by an oil jet.
Now heres the kicker part.
Obtain a RHF6CB Turbo And Turbo Manifold. 90-94
You will need the "Turbo Oil Return" oilpan BPT-DOHC. 90-94
Keep the Stock IntakeManifold, BP DOHC. 90-94
Keep the Stock BP DOHC Cylinder head, My casting # is BP05-8-2.
So far all i have read is that these parts were screwed around with in the us customs, and scattered thruogh out all the other motors, the motor after built and retuned is supposed to squeeze atleast 300BHP, using all stock Parts.
Im Researching the F-Type Tranny right now. will post swap list later.
oh ya you will need the F-Type 1.6litre tranny "B6 SOHC"
You will need the Flywheel F-Type 1.6litre "B6 SOHC"
You will need the F-Type Clutch and Clutch Disc 1.6litre "B6 SOHC"
Piston history.
