#1006 | |
So are you the 'as of yet unnamed' second tester?
Quote:
__________________
'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. '93 Ford Probe GT - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 10.24 @ 139.5 mph [16 psi] - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 490whp, 447 wtq @ 20psi - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#1007 |
Registered User
I wish. I'm pretty sure my co-drivers and I could put a diff through it's paces. My car has had over 100 runs on it just in the last 3 weekends with several Solo II National Champions driving it. There are only a handfull of agressively built autox/track G-series cars around that could be good testing platforms. I'm hoping we get some good feedback from whoever it is. I'm in a rush now to get my car back together before the Blytheville ProSolo and Tour at the end of May. I think I'm on the extremely short list (maybe the only one on it) of N/A Proteges that have broken a "revised" Mazdaspeed LSD.
__________________
#1008 |
shoulda welded it...
i'm curious who this 2nd tester is as well, somehow i'm out of the loop here
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. The first FWD BG with a Toyota E153 transmission conversion, in the US =o To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#1009 |
Registered User
I should have. I didn't figure an N/A car would have needed it. My big tires beg to differ. This was the revised LSD that was supposed to solve that issue.
__________________
#1010 | |
I'd talk to mazda and see what they can do about that diff. Replacing it at a discount should be in order.
__________________
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. ._________________________ |.....Overnight....................| || |.....Japan Parts.................| |'|";,___. |_..._...____________======||_|_|...,] "(@)'(@)""'''''''''''''"'''"**|(@)(@)*****"(@) Quote:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#1011 | |
Registered User
Quote:
I'm going to contact Mazdaspeed Motorsports tomorrow. I don't plan on using a MSP diff again, but it would be nice to have a functional one I can sell.
__________________
#1012 |
Registered User
I had my doubts about the revised unit, boy am I glad I didn't go for it.
I'd love to test the diff as well, while I don't have the grip and tire that XelderX has, I do make a good deal more torque, and certainly could put it through it's paces both in autocross and on the road course. For your consideration ![]() Autocross: http://videos.streetfire.net/video/M...gin_636119.htm http://videos.streetfire.net/video/M...-on_156052.htm Miller Motorsports Park: http://videos.streetfire.net/video/F...ler_194146.htm Of course, with one in a DSP car, and another in an STX car all bases would be covered
__________________
Ryan '94 Mazda MX6 V-6 STX Prep: MFactory LSD [] TEIN [] Enkei 17x9 RPF1 [] Toyo R1R [] Hawk HP+ [] Schroth [] Corbeau [] AWR [] HotShot [] Headers [] Magnaflow [] Side Exit [] Last edited by Inspector 24; 04-09-2009 at 12:44 AM. |
#1013 |
Kosta
yay just payed the other 325 of my deposit. now
I don't have to be scared that I'll spend it on something else. ahahahaha |
#1014 |
Member
Thanks :D
#1015 |
Registered User
Mfactory, I've seen in the HondaTech.com reviews that your diff used Belleville washers to apply some pre-load to the axles to prevent open-diffing should one wheel come off the ground, say over curbing on a road course. How much pre-load to the washers apply? Is this adjustable?
Ryan
__________________
Ryan '94 Mazda MX6 V-6 STX Prep: MFactory LSD [] TEIN [] Enkei 17x9 RPF1 [] Toyo R1R [] Hawk HP+ [] Schroth [] Corbeau [] AWR [] HotShot [] Headers [] Magnaflow [] Side Exit [] |
#1016 |
Member
The washers are more for noise-control than pre-load
#1017 | ||
can someone fill me in a bit more about the use of these washers???
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. 1990 mazda 323 (4th 323) ........ 1993 mazda MX3- KL swap+goodies Quote:
Quote:
NAProtege: normal NAProtege: ? bpt323: woot!!!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#1018 |
Registered User
#1019 |
Member
They are used to prevent slop/delay in response when you go on/off the throttle. Without them, the lsd will still function, that's why I just call them noise-control :p
#1020 | ||
willkill, do a google search for bellvillewashers & LSD. theres a few informative reads
__________________
| Thread Tools | |
| Display Modes | Rate This Thread |
