Ok for sale i have a few odds and ends as i finish spring cleaning
First up i have a clean BPT (bp26) exhaust manifold, now it has a flange for a vj20 but im sure you can find someone to make an adapter plate so you can bolt on what ever turbo you want. i know someone was making some on wihandyman.com at one point. $80 shipped with in continental US
Next is a set of HLA's from a bp, i was at the junkyard puling a valve cover on a protege and when i pulled it off and saw how clean the HLA's where i decided to grab those too. they have been sitting in synthetic oil since i got them. $35 shipped to lower us obo
aeromotive EFI adjustable fuel pressure regulator, needs a rebuild has a hole in the diapghram Summitracing.com has rebuild kits.
45.00 shipped
MSD adjustable timminf control, allows you to adjust the ignition timing to compensate for changes in altitude, low octane gas, or heavy loads. For cars driven every day but raced occasionally on the weekends, this control is perfect. Increased fuel mileage and performance are just some of the benefits as the ignition timing can be advanced or retarded to prevent engine detonation. The control knob mounts to the dash board for easy and accurate tim*ing adjustments up to 15°.
like new condition 95.00 shipped lower 48 states
miata obx down pipe 40 bucks someone come picks this thing up!!
45.00 shipped
