Well guys, I've finally got round to fitting the 460cc Series IV (i think) 13b N/A injectors I got off ebay ages ago. Reasons for not fitting was that after I'd been told that all RX7 injectors are bolt in, THEY AREN'T. In the RX7's, any of the Peak and Hold series injectors (low ohm/impedence) have a bigger nozzel than the Saturated (high ohm/impedence) injectors found in the later 13b N/A engines.
I had the injectors serviced prior to fitting...this included replacing the nozzel caps, head seal (grommet), top grommet, o-ring and also cleaned and flow tested. Cost was $30/injector.
Well anyway, fitting wasn't hard once I got started. Intake pipes and intake manifold were removed so that I could insure that no metal would get inside the engine. With making sure the valves were closed and a rag wedged in the port I proceeded to drill (with gritted teeth) the injector ports in the head larger. The standard port is 9.5mm and I redrilled exactly 1mm larger and this made a perfect fit for the nozzels on the new injectors.
Apart from the head ports, these injectors fit perfectly into the standard GTX fuel rail.
Again the difference with the low ohm injector out of the RX7 is that the plug is different...I already had a set of plugs lying round in the spares bucket to suit, so it wasn't hard to me to chop and solder and heat shink the plugs into the injector loom I made for the Microtech. Because I do have an aftermarket ECU, I don't have to worry about a resistor pack...they just plug straight in and the Microtech will drive them with no problems.
I have already started the car and as expected it was very rich. Haven't attempted to drive it yet....will do that tomorrow and attemp a quick road tune with ajusting the injectors pulses down to a safe level that I won't go through a tank of fuel a day and stuff my spark plugs before I can get it retuned for more boost and power :D
Aim is for min of 220WHP on whatever boost the mighty VF10 hybrid will manage. heheh.
