Well I just finished up swapping the transmission in my 94 LX and the tranny shifts fine, but the clutch slips so bad it is not driveable! It seems like the clutch isn't engaging all the way because it only starts to grab when the pedal is more than 3/4 of the way up. The clutch pressure plate and disc and bearings are BRAND NEW. I have bled the release cylinder to death trying to fix it.
Here are my two ideas:
1. I swapped the release cylinder from my DOHC tranny onto the SOHC tranny, are these interchangeable?
2. I am really hopping this isn't the case but maybe an oil seal in there has failed which is lubricating the clutch and causing it to slip.
I am leaning toward the first idea because I think it isn't engaging all the way. Anyone have any input or ideas I could try it would be much appreciated.
