installed an na head on my bpt ever since then ive been hearing what i thought to be a boost leak. it only happens when im driving along wot above 5psi.
pressure tested from the turbo on and fixed the leaks that ive found, rigged up a cap with a valve stem to fit on my turbo inlet.
ran the car on the dyno to see if i could hear and locate where its coming from couldnt seem to find because A it was either to load in the shop or it B wasnt making it.
tried the smoke machine on it found and fixed some leaks but nothing significant.
im going to check the cat the see if its plugged... not sure what else to do
