Originally posted by atomicEGT
View Post
what can I take from BP-4W?
http://rusefi.com - open source ECU
pull the whole motor & be done with it.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I have removed the head & hidden it at the yard - my plan is to buy it 50% off during the sale next weekend.
Funny thing - there were three BP engines in the yard (this miata, older miata and an escort gt). On all three the valve covers are gone. Who the heck would need so many valve covers? I know both miatas were added to the yard THIS week.
Anyway, on top of the intake mounting another difference is the coolant inlet - on the miata head it's on the head, between the cam gears.
What is the plan? Which inlet should I use and which inlet should I plug? What about the coolant passages inside the head and between the head and the block - is this going to work at all? I guess I should check if head gasket is the same but something tells me it is not.
I will go PM ftjandrahttp://rusefi.com - open source ECU
Plug the hole on the front of the Miata head with a freeze plug (30mm iirc). This makes the front identical to a Protege head.
The rear (Miata orientation) of the head is also slightly different. The Protege head has a pressed in fitting that consists of two nipples - a large one for the heater core feed and a small one for the oil cooler feed. The Miata head only has the smaller one. Easiest way to get the heater core feed back is to use a spacer between the head and thermostat housing with a barb for the heater core (pre-thermostat).
Use the Protege head gasket.
--FerdiIf you can't differentiate between brake and break, you should go back to school
Originally posted by ftjandra View PostPlug the hole on the front of the Miata head
We are already running without heater - the hose is just looped instead (that's a race car and this way it saves us a minute on each engine swap). I guess we will simply shut the heater line down, I guess that's the same as running with heater turned off?http://rusefi.com - open source ECU
Water is always flowing through the heater core whether the heater is on or off. There is no bypass valve like on some other cars.
A small amount of coolant needs to bypass the t-stat for everything to function correctly (I forget the actual reason). If you are blocking off the heater core hoses completely, I'd drill a small hole (~3/16") in the t-stat to act as the bypass. That's what we did on our race car.
I bet your race car takes forever to warm up with the lines looped.
--FerdiLast edited by ftjandra; 11-23-2013, 07:19 PM.If you can't differentiate between brake and break, you should go back to school
Originally posted by ftjandra View PostIf you are blocking off the heater core hoses completely, I'd drill a small hole (~3/16") in the t-stat to act as the bypass. That's what we did on our race car.http://rusefi.com - open source ECU
Does your engine ever get up to temp? Especially where it's cold like in Chicago?
Originally posted by ftjandra View PostDoes your engine ever get up to temp? Especially where it's cold like in Chicago?http://rusefi.com - open source ECU
That's not really optimal for wear or anything. Ideally you'd want to be at least 180°F. You'd get better mileage too as it would be running super rich at those low temps.
Originally posted by ftjandra View PostThat's not really optimal for wear or anything. Ideally you'd want to be at least 180°F. You'd get better mileage too as it would be running super rich at those low temps.http://rusefi.com - open source ECU
Originally posted by russian239 View PostFunny thing - there were three BP engines in the yard (this miata, older miata and an escort gt). On all three the valve covers are gone. Who the heck would need so many valve covers? I know both miatas were added to the yard THIS week.Beater=/= Sleeper
Originally posted by kozzman555kitty, you are a hilarious womanOriginally posted by HopelessCowthere is one thing i dunno what is that call,a thing look like a gun, u press the button and stick to the metal and it makes firework, do i need that thing?and what s the philip head screw drivers?
15/45/70---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Work is still in progress but here are some pics:
I think what Jim did here is just beautiful.Last edited by russian239; 01-18-2014, 08:02 PM.http://rusefi.com - open source ECU
