just a couple heads up:
better keep all the sensors for teh fan and cooling stuff off your 323. you will need to use some of them on the ford bp do to the ohm loads being different.
running 205/50/15 will make your speedo run slow. 195/50 is the correct size for the 323 speedo. you will also need the protege LX speedo sender. the f series one will nto work.
NEUMAN
NEUMAN
