wow..... sweet. i like the EGT bumper on the 323.... looks pretty neat
Sock's BP-Swappin' 323 Project Thread (Comments Appreciated!)
Ex-Officer: INTENSE Performance Mazda Club of South Florida
JDM nut & AutoXer: 1992 Blaze Red Mazda 323 S
262,000 miles and kickin... and got some wicked new goodies recently...
BP Engine Build: Soon... Engine on the garage floor, parts on order
"Ever seen a 323 on Anthracite 17" OZ Superleggeras?!?!
...... and more importantly ever seen one with matching 15" Superleggeras for Autox??"
To start things off, there's a small video that I uploaded.
After a few cranks with the coil unplugged to build oil pressure and fuel pressure, I started it up for the first time since removing from the Escort.Donor: ...
Yeah, that's right. I finally did it.
Installed the rest of B6 the intake system. The Escort GT one was torn to crap. This stuff is like Lego.
Wired up the relay for the foglights.
Old filter vs. the longer Toyota filter. More filter = better, right?
Installed. Lots of room.
All buttoned up for tonight.
Originally posted by almighty4wd View Postwhoa whoa. Toyota? I musta missed that. What Toyota/year is that from? That's even bigger than the 626/mx6 filter.
With Toyota, there's two primary filters. There's the one that's the same as our, PH6607, or the longer PH7317 on some of the trucks, etc.
I just sell auto-parts (PartSource), so it was something I came across from working there.
The part numbers are right there on the photo - just print if off and get your local parts place to cross reference the number (PH7317) if you want the bigger filter.I peered out from the castle window and looked over the splendor of ROTM county. Yes, twas' a much simpler time back then. Peasants would go about their postings, and I, the mod, would rule over them with an iron fist.
GOOD JOB MAN!!! WOOT!!!! Go take that thing for a rip now!!!!
JACK.-Jack
damn.... sweet man. i like the video.... no fiery header shots tho lol
so is it true that bigger filter = better??Ex-Officer: INTENSE Performance Mazda Club of South Florida
Originally posted by Devl323 View Postso is it true that bigger filter = better??I peered out from the castle window and looked over the splendor of ROTM county. Yes, twas' a much simpler time back then. Peasants would go about their postings, and I, the mod, would rule over them with an iron fist.
Passenger side strut installed.
Hole in driver's side wheel well fixed.
Exhaust installed.
Here's a clip of the exhaust. I'm not really impressed, but whatever. I'll fix it some other time if it gets too annoying/embarassing.
All done for the night.
looks good.
i looked up that filter at advance auto and it is in the list for mx3 filters, doesnt show it for toyotas tho.1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
Also, on your down pipe section, you will want to put some kind of support to it, from the engine block. The weight of the exhuast moving around, even with the flex section will eventually crack it otherwise. Look around your B6 and the BP both should have had something. It's just a stamped plate or two that comes down and uses a "U" clamp to hold the pipe to the plate. Nice work, you'll love the new power...
-Jon R.
