Using the Corksport vents as a template, I then traced the inside and outside perimeters with a sharpie once I had everything lined up and centred. Removed he templates then cut the insides using a dremel and zip cuts. On the long straights I used my 4" grinder with a zip cut wheel on it.
WilyB's 93 GT rebuild
New Thread:
Old Threads:
Once the holes were cut I took the oem vents, dabbed liquid paper onto the tips of the screws and pressed them gently onto the hood following the traced marks I had on the hood from the other set. Worked well... drilled 1/4" holes into the hood, installed the oem vents and scribbed the inside edges of the vents onto the hood. Puled the vents off, cut some more with the dremel.91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
New Thread:
Old Threads:
New Thread:
Old Threads:
damn looks good man!!!-Jack
Paint complete
Spray bombed the underneath with an epoxy based hi temp paint yesterday, then 2 coats of base coat and 4 coats of clear on top. Needed to put lots of clear because I had some major orange peel... there is still some however not as bad as when I had 2 coats of it...Not much interested in wet sanding...I'll give it 24 hrs to dry then install the vents.
Notice the small dents from a ball peen hammer on the inside front lip... needed to do that so the hood would close and clear the fog light grill. I would have filled those holes with bondo or a sheet of fiberglass, but it would have ended up touching again so I left it like that... no biggie...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
cutting the vents is fun isn't it (sarcasm) looks great afterwords tho... im impressed with your foglight notchouts also.
bump for install pics---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
New Thread:
Old Threads:
fin sexy!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Thanks! The underneath will need another coat...I used the epoxy paint there and as u can see it didn't quite darken enough... that front part was down to the bare metal the rear part wasn't. I think this is also a sign that I should paint and clear coat the engine bay instead of using that paint...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
GTR bumper
Started on the GTR bumper. Drilled out the spot welds at the mounting points on the driver's side straightened it out and bolted it up for now until I can test fit it with the bumper cover on the parts car outside as it has fenders on it, my GT doesn't. Needs a bit of tweaking still it's pointing downwards a bit. I also fixed the kink in the cover...clamped it up using a steel flatbar to straighten it then put a heat gun to it... turned out perfect...
I was wondering how long it would take to cut a finger or something while I cut out the grill, as it was bound to happen... nicked a finger and thought that would be the end of it until I deeply stabbed my thumb with the utility knife....bled like a stuck pig!!
As you can see, the grill was replaced...not quite finished but it will look good!Last edited by Wilyb; 05-03-2012, 09:20 AM.91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
New Thread:
Old Threads:
ive always loved that grill. but every time i see that bumper, it makes me think of someone that just had there teeth pulled. like they have the mouth full of cotton balls. lol~PaTricK~
-Current car's-
What are you driving?
LMAO!!!
Now that you mention it...yeah it kinda does doesn't it!91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
