that evapo rust is just muratic acid alot of body guys know, if you use it make sure you seal it up right away or it will flash rust quickly i would recomend a etching primer
WilyB's 93 GT rebuild
Thanx for that info egt... I'm simply going to go buy new and be done with it...Mr. demon, I'll check that stuff out... it must be rust converter... I have it in spray.... Hot wheels, Thank you for that info, I was wondering what it was that was the active ingredient in there... Yes it does flash rust very quickly. It was suggested to me to use Muratic acid when I went to the Hardware store in my quest for phosphoric acid...Last edited by Wilyb; 09-03-2008, 07:23 AM.91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
New Thread:
Old Threads:
yeah holes
Yeah there are a couple of them... bought a Mig welder the other day...next move... wait until u see the size of the other hole... just goes to show that a rustproofing treatment doesn't get everywhere...
New Thread:
Old Threads:
Hey Crep,
did you look at the car when you were over at the house the other day? what did you think?91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
New Thread:
Old Threads:
Update
Did a majority of the work on the inside driver's side. removed wht I could and cut the rest... As you can see there was a major dilemna at the rear driver's side which is salt side hence the reason for more rust on that side than the other (passenger side). I have all the replacement metal shaped and ready to be welded on, but I'm going to leave it until spring. temperatures are too cool for primers and paints so there's no sense in welding now.91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
New Thread:
Old Threads:
New Thread:
Old Threads:
New Thread:
Old Threads:
New Thread:
Old Threads:
you should make a rotisserie!
JACK.-Jack
