tokico hp blues on sale for 82.92 each at http://www.performancecenter.com
MATT91GT's 91scort Worklog
Updates?????
any new pics or new info?91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
The rest is bone stock.
its been several months since i have updated this. its time for a few new updates.
over summer i had the car in class for a few weeks. i did a few modifications during that time. I had removed my steering rack to install a de-powered mx-3 rack, i ran into complications with that install so i reinstalled the original rack with the steering lines cut. I installed mx-3 LCAs with energy suspension bushings. I removed the A/C compressor, lines and condensor as well as all the power steering lined and pump.
Fall. In october i removed the evaporator case so that i could pull the last remaining A/C part. A good day at the junkyard got me the proper bracket to mount the mx-3 center console finally (after months of it just sitting in its position).
Last week i gave in and purchased a new set of headlights on eBay. I couldnt deal with the hazy old headlights anymore. my foglights emitted more light than the headlights. i have yet to take a picture of the new look of my car. i will post it up once i do.
Today i purchased 04 mazdaspeed miata rear calipers and rotors as well as replacement brackets for my addco rsb. up next on the list are a couple sets of camber bolts so that i can properly align my car.1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 EGT - Junked May 2012
ill snap pics once they arrive1994 Escort LX Wagon
today i installed the rear brake upgrade. 04 Mazdaspeed Miata calipers and rotors. Rotor diameter increases from 9.8" to 10.8" took a few hours because i had to keep running back to my apt for more tools. looks really nice compared to my old rotors and calipers.
old
new
fills out the wheel much more than the fronts
These are approx. .55" larger than the fronts which are 10.25"1994 Escort LX Wagon
looks good man! just break em in then you can check how good they stop haha-Jack
blew the head gasket out on thursday. brought it into school today and started taking the head off. didnt get very far because i had to get to my next class. depending on the severity of the engine or head i want to rewire my harness and remove the plugs i dont need anymore. i also plan on shaving some things and doing a wire tuck of sorts1994 Escort LX Wagon
got the head off today. a piece of the gasket was hanging out from between the layers. oddly no signs of coolant in the combustion chambers, even tho coolant was coming out my exhaust. the valves are black, pistons are dark. i can still see some crosshatching on the cylinder walls but there is also some scuffing in cylinders 2 and 3. i need to replace the water pump, timing belt, tensioners, coolant hoses, head gasket. the head is warped .002" so i need to get that machined. i think im going to just get a replacement engine. and a new clutch.1994 Escort LX Wagon
