Do you know that you have to run it in-line with pin 6 not just take pin 6 out of the ecu and put pin 19 into pin 7
the bpt wagon work log
Sick!
That has got to be the sickest wagon I've ever seen. What's next?91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
The rest is bone stock.
Originally posted by bomdoutscort View PostDo you know that you have to run it in-line with pin 6 not just take pin 6 out of the ecu and put pin 19 into pin 7
turpro what now i need a auto throttle body for the 4 wire tps to work ? i have 3 throttle bodys whats the differnce bettween them ?
u guys got me all confused now .
You don't really need to do a 4 wire tps swap but it does work better when its done. I replied in your other thread. And iirc you do need to swap the wire from 19 to 7 even with the 3 wire. Its a tps signal wire. On the usdm ecu slot 19 is the tps signal slot. On the gtx ecu slot 19 is nothing, slot 7 is the tps signal. Mine still ran without flipping any wires when I had a 3 wire but I got 21-22 mpg. Now I'm getting 25-26 but I have boost leak so its not running 100%Last edited by Turpro; 02-04-2009, 06:11 AM.1993 Protege LX-Midnight's shadow SOLD
i ajusted the spring on my greddy knock off bov all the way in and finnally have a smoother idle and midrange rpm now its just idling still allttle to high im gonna swap out my bp throttle body for my bp26 throttle body and hopefully since im using my old iacv from my previous motor that i know works well it will be fine .
well the gas milage is better and the hiccups are gone no im finding out tommarow how much of a used fmic kit i can pick up im not interested im pushing more than the gtx ecu can handle because i would take me along time to save for a mega squirt .i clear coated the rims and did some welding on things last night like the hood latch keeper broke off and my cross member had only 1 bolt holing in in the front so i welded the pass side of the cross member to the frame . plus i have 2 mikitx grinders so i dont care if i ever have to cut it of .ha ha
i got polyurathane front and rear sway bar bushings installed to day and im working on another red ford valve cover im a bit sketcy about the local cops asking me to pop the hood on a ford and it says mazda a buddy of mine got sent to the referre that way and then had to put the car back to stock plus white is just too flashy .
