today i changed intake manifold gasket tb gasket put the harness from the protege in it along with the 3 wire tps throttle body
it looks like there was a lot of silicone used between the tb and intake manifold its all up inside the throttle body so i had to change it out all the injector caps are cracked and a 2 of the injector seals are cracked
Sick ****. I will get back on my audio kick after my swap.
This is my BP. There are many like it but this one is mine. My BP is my best friend. It is my life. I must master it as I must master my life. Without me, my BP is useless. Without my BP I am useless. I must drive my BP true. I must drive straighter than my enemy, who is trying to beat me. I must beat him before he beats me.
i love seeing my craftsmanship in other peoples cars. to bad everyone else has cooler stuff then me! thanks for the deal doug can't wait to do the next touch for you.
awr passengers side mount will be here the 25th i will be installing it along with the front mount and taking some pic's hopefully i can get the front mount in with out killing my radiator with the wastegate pipe
