well got the gauge pillar today
bpt mx-3 worklog
fixed the wheel studs they had some of the lug nut stuck in the threads reinstalled the wheels and slammed it to the ground waiting on new extended lug nuts to get here to replace the old ones had to toss 4 of them out they were stripped bad
list of stuff coming in the next few weeks
new audio install
rust proofing floor and trunk
new carpet
battery relocation
install seats
start it up maybe
i am relocating my battery to the trunk so i have a spot to mount my msd ignition box would there be a problem running it with the battery in the trunk
new battery mount
plus i will be making a flat mounting surface that will bolt to the stock battery tray location where the msd 6al 150-200 amp circuit breaker and will be mounted
Originally posted by smoke187 View Posti am relocating my battery to the trunk so i have a spot to mount my msd ignition box would there be a problem running it with the battery in the trunk
mounted
i wouls used an enclosed batteru box with a vent. some tracks require it to be enclosed and to have a vissible cut off switch. you dont need to follow those recomendation if you dont plan on going to the track. use the biggest gauge cable possible for positive. i have an upgraded altanator too but i still have problems some times with charging
