you might wanna get a string or something tied around the trans thru the axle holes or your gonna be REALLY pissed if someone hits your tranny with something and the gears FALL IN the case, just when you think naw that will NEVER happen to me guess what IT WILL!!!! but looks great so far good luck on the build
91prodx to bp swap - deathtrigga
http://www.wihandyman.com/forum/vbpi...?do=view&g=228
Mazda's Rule Honda's Drool
take a piece of heavy string or something that you can TIE in a knot and go THRU BOTH THE holes for the axles and tie it tight!!!! if someone bumps that trans the wrong way the carrier bearings WILL fall into the case and really make your day a crappy oneCheck out the Pics
or cram a axle in it so the gears cant fall, if you look @ my build pics youll notice a axle NEVER left the trans if i could help it http://www.wihandyman.com/forum/atta...1&d=1239663281 trust me if they fal and you dont notice it you will be replacing the trans the first time you start it it will **** the transLast edited by 90prtege; 05-29-2009, 10:28 PM.Check out the Pics
no problem i thought ahhhhhhhhh it could NEVER happen to me and well IT DID and cost me 350 bucks for a trans for my pro about a year ago. just wanna save someone else the BAD LEARNING experience i had and MANY of our members here have probably had happen to them alsoCheck out the Pics
So here is the painted tranny
taking this things clutch flywheel pressure plate for now and ill upgrade when i go turbo
here she is mounted the paint got dirty but it can be cleaned up
look i got the string attached through the axle holes now
just some shots at the shop
theres my baby
changing my friends rear calipers, rotors, pads!
since im crazy and i want the engine bay to look clean i decided that the radiator fluid reservoir sticks out too much so i decided to cut it and epoxy it somewhere down the neck a little so it hides it, i think it looks pretty decent so far.
before
after
Check out the Pics
