if it's just tightened up over time, it's probably build up...either way it's not a bad job R&R the shifter linkage and replacing the bushings it's a worth while maintenance thing for the BG chassis, you can also get fancy with Bronzoil bushings or flanged bearings
EGT worklog
The car sat for almost 2 yrs and it stiffened while not being used.
I figured on either replacing the bushings or being able to lubricating them.
They are possibly rusted or something.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
The rest is bone stock.
the oem bushings are plastic . be gentle getting the bolt loose because that will be your issue . a little sandpaper if the bushings arent completely toast and some moly-lube and you should be ok . be sure to roll the sandpaper and run it through the shifter base then re-insert the bushings (available at mazda for cheap )if you dont want to spend for bronzoils , be sure to pack grease in between the 2 bushings as a reservoir before you re-insert the bolt . the nut is a nylock replace it with a new one from home depot ,and dont crank it down . just snug it up to take the play out but allow everything to swivel easily
^ perfect advice---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by MazdaNoob View Postthe oem bushings are plastic . be gentle getting the bolt loose because that will be your issue . a little sandpaper if the bushings arent completely toast and some moly-lube and you should be ok . be sure to roll the sandpaper and run it through the shifter base then re-insert the bushings (available at mazda for cheap )if you dont want to spend for bronzoils , be sure to pack grease in between the 2 bushings as a reservoir before you re-insert the bolt . the nut is a nylock replace it with a new one from home depot ,and dont crank it down . just snug it up to take the play out but allow everything to swivel easily91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Got some cleaning up done this past weekend. Wanted to see what it looked like under all that crud and dirt that accumulated on the car these past 2- 2.5 yrs.
I know there needs to be some bodywork done and a new fresh coat of paint, but I still needed to know what I'm working with.
This is what I found!
Not to shabby considering! I got a quote from a regular customer of ours, and he offered to do the bodywork and paint for $600.00's
I don't know if thats good, but it sounds reasonnable.
Also, these are the wheels I've been talking about getting when we get the title.
Hope to get the title sometime this month! The state s just dragging there feet with it.
They are Motegi's and they are on an Integra with heavy high hit front damage. Wheels are good and the turbo is good.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
$600 seems like a good deal, what are you going to do about the front bumper? Go back to an EGT one, or fix that one up?-Jack
Originally posted by Mazda_Powered View Post$600 seems like a good deal, what are you going to do about the front bumper? Go back to an EGT one, or fix that one up?91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Yeah that would be cool! Sorry!91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Found a nice red EGT in the junk yard over the weekend, but didn't have enough money. @$#%%#@
I get paid this Friday, hopefully it's still there, because it has an almost perfect red EGT front bumper!!! Woot!
Also am going to grab everything I can for the silver cars build.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Well, it started off to be a great day! Got to the junk yard where I found that red EGT, got the bumper off, carried it out, paid for it and went to leave. It had started to snow while I was inside paying for it, stepped outside and started down the steps and wouldn't you know, I slipped and fell and broke my new GT bumper! Son of a B@$%#! So now I have this P.O.S. of a bumper that I'll have to try and fix!
Stupid snow!!!!!!91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Normally no but it's been cold here for a couple days below freezing, and that'll make em brittle!91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
