does the pump prime when key on after sitting for a bit ? is it getting power when cranking ?
EGT worklog
When the keys on for a bit, I don't hear the pump come on at all. When cranking there is no fuel getting to the fuel rail.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
The rest is bone stock.
bypass/jumper the fuel pump relay. and also check the ford fuel pump fail safe button<<<< do this first.....---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Im not sure what you mean by bypass/jumper fuel pump relay. Already checked the ford fail safe button and even bypassed it and nothing.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
find the fuel pump relay- it has a trigger & a ground on one side of the relay. a through power circuit on the other side.
take a paper clip & jump the trigger/ground & see if you get fuel---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bomdoutscort View PostHave you tried the fuel pump cut off in the trunk? That might have been tripped, so its been asked already. How about the vaf meter? It controls the fuel. Make sure its plugged in all the way.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Ok, we checked everthing with the test light and found that everything is good except the fuel pump, so I'm going to replace the fuel pump and fuel filter this weekend and hopefully thats all. Please fire, please!!!!!91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Originally posted by scort4life View PostOk, we checked everthing with the test light and found that everything is good except the fuel pump, so I'm going to replace the fuel pump and fuel filter this weekend and hopefully thats all. Please fire, please!!!!!
I have a guy willing to do the timing for me but he's swamped for 2 weeks.( Damnit) Until then.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
Well it turns out that we did the timing wrong and I had the firing order screwed up.
My buddy at work was able to figure it out after doing the timing all over again and found the issues with the wires.
She now fires up on the first time every time and is running real good!!
Now to get it on the road I have o replace a few things, and then off I'll go.
Thanx everyone for the input and ideas to get her back on the road.
I'll be posting new pics once she is back on the road and I have my new wheels installed.
Forgive the ugliness of the body, but thats last on my list.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
95 Probe SE- Sold!
a good cleaning & a nice buff/waxing & even the exisiting paint would look good.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I've noticed the other day that driving it around my companies property that the shifter is real tight.
If i were to spray some lube on the bushings would that loosen tem up? Or do I need to replace the bushings all together?91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
just loosen the bolt a small bit.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postjust loosen the bolt a small bit.91 EGT- bodykit, clear turn signals, smoked tailights, clear side markers, WRX style(functional) hood scoop, WR CAI, 2.5" Tanabe stainless steel exhaust, ported and polished head, ported and polished intake manifold, MSD blaster 2 coil, Magnacore 8.5mm wires, MX3 seats, custom detailed engine, N1 front and corksport rear tower strut bars, KYB struts, N-1 coilovers, MX3 rear tie bar, custom detailed interior, Sunpro gauges, Ichibahn steering wheel, cross drilled rotors, Ebay short shifter.
95 Probe SE- Sold!
