I wish I was into detail. I just like to haul ass. Great job
I got my front Struts / Camber Plates / Helper Springs all buttoned up over the weekend .....
just waiting for some suspension dust boots to finish them off before installing ..
I had to machine up all new top cap inserts and spring spacer to make it all work .
Then I had some extra time, so I decided to clean up the front of the engine bay area.
I was all prepared to install the cross member and all the lower suspension and noticed
a number of small areas which had starting spots of rust. So I couldn't see myself putting
it all back together with the rust potential eating away the front end.
I did the lower front area which you will never see once all the front end is back on it , but
as an after thought I did the whole front end after I shot these pics. I will post a finished pic
with it all newly painted once I strip away the paper/tape .
thanks for the porn lol, those coilover sleeves turned out awesome man. So what are the specs of the old spacers you couldn't use? Not setup for 2.5" ID springs?
Got some progess done ... think I am at the point where I can drop the Engine and Tranny back in her next weekend .
Installed the newly powder coated cross member and the 4 point lower from tie bar , trial fitted the new radiator, new radiator s.steel hose clamps ,installed the fan assembly to the radiator, new gas lines , new fuel filter ,
