awesome!
lookin great!I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important.
._________________________
Today's work:
Throttle pedal mounted - the JDM car has the mount points integral to the firewall (nutserts welded to reinforced portion of the firewall), and since I didn't want to weld some nuts to a thin shell, I just took the LHD mounting bracket, trimmed it, and welded it in the proper position (there are guiding dimples in place) for RHD.
Closeup of throttle pedal bracket
Clutch M/C holes - here I thought I should avoid cutting - so I just cut out the RHD portion of the clutch M/C and used it to trace the shape - then I used the proper hole saw (1 1/4") and drill bits (25/64") to make the holes. Fits like a glove.
Pedals installed - mocked up to align the inside bracket, outside 'patch' and the mounted top brackets for the pedal assembly. As they sat like that, I tack welded the inner bracket, removed the pedals & M/C, then aligned the outer patch to match the inside and it all came together.
Outer patch stitch welded
End result - looks factory
'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
very nice, coming along nicely for sure91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
gonna patch all the holes you're not going to use now? lookin great man-Jack
Yes, that's part of the cleanup process when the essentials are done.'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
i like super tits91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by 1992tracerlts View PostYou should do a wire tuck and make this look super tits.
That's also being done. I think I mentioned it in passing on page 1. I bought a brand new mx3 wire harness, and combined with the old one I will have plenty of wire to extend it where I need, keeping the same gauge and color and plugs. It won't be a show car tuck (I'll be leaving the hydraulics mainly untouched) but I don't want no more wire spider webs either. Battery's going to trunk for more rear weight balance.
The engine appearance inspiration comes from the 2001 Mazda 626 MPS concept car - this will be the engine bay color scheme, except not as cluttered:
looks sweet, i think im going to get the valve covers on mine done black. so freash and so clean91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by Dan [Sac] View Postbut the blower motor will have to be either a universal unit or source out another one.
And I still forgot to order the manual RHD steering rack, as the GTX one is power and I can't stand the leakage and space taking and weight. Can't do a wire tuck with a bunch of PS lines taking up the room in there.
Your GT-R stuff is probably all electric and won't have the correct plugs either. Also you most likely have power steering, which I passionately dislike.'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
