just bought a dakota digital tach signal interface. shipped out soon and hopefully to my door pretty quickly.
klze swap
looks like a good size too me though, I can see why you grabbed it! OEM = too bulky-Jack
Originally posted by Mazda_Powered View Postlooks like a good size too me though, I can see why you grabbed it! OEM = too bulky91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
ive always loved the mazdaspeed pro's shift knob. but putting it on a 5 speed, when it plainly marked for a 6 speed is kinda ricey. i would find something a bit more appropriate man. false advertising like that should be left to the honda kids.~PaTricK~
-Current car's-
What are you driving?
Pat it is a 5 speed shift knob lol it says R where 6th would be technically
So why won't it screw on? different thread pitch??-Jack
odamn. ur def right. i had the newer speeds in mind.
i know the newer mazdaspeed's are different. and wont swap as i have a OEM mazdaspeed6 knob. and it wont even fit on my n/a mazda6. but my mazda6 is the typical normal mazda thread pattern. so id bet its probably all the speeds are different dating back to the protege.
the weird thing about that is the MSP wasnt even a real mazdaspeed vehicle. and was built out of house. which would make you think something like that wouldnt have changed.~PaTricK~
-Current car's-
yup this is a 5 speed knob. i love the look of the speed 3 6 speed knob but i wont do that unless i bolt that tranny in it. thread pitch is 10 x 1.25. my shifter came out of my parts mx-3 and was a little bit butchered and i think the shifter knob had interferance problems with something on it. might work on a normal unmolested shifter. got the shifter boot and not sure if its going to work but dammit im going to give it a try.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
tried installing the speed 3 shift boot, um......yeah. i can get it to work but i dont like the fit and finish of it on the base so this idea is gone and have to go a different route. slinky boot stays for now.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
just order one of those nice leather mx-3 ones? Or hit up the wreckers lol they fit perfectly...why mess with a good thing-Jack
i have one from my doner mx-3, ripped but comparing side by side it seems way too small. my mx-3 was a 96 so i dont know if the earlier ones had a larger boot91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
they may have! I know the ones that come in the earlier models are a direct replacement since those are the only ones I seem to find lol-Jack
it's actually pretty easy to install! minus adding the extra bung if you don't have a welder lol....lookin good tho man...keep that KL running proper!-Jack
have the mig welder but it craped on me when i was about to weld the shifter. havent had time to see if its the welder itself or the fuse for the power box91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
