I like the look of the 3rd gen steering wheel.
klze swap
splines between the two wheels are the same. the newer wheel didn't have the hole for the clock spring in the right place so I had to dismantle the wheel and do some cutting. also the back of the wheel needed some modifications for the turn signal nipples. bg wheel has the holes north south vs west east on the other. just marked the back and made new holes with a step bit. easy peesy91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
after the cutting and drilling. completed a test fit. I think it looks great in the old car. also removed the igniter from the airbag so it is depowered. all I need to do is figure out what im going to do to mount the bg cruise control buttons. I have an idea for that. when I complete it I will post up some pictures. so far I am happy with how it turned out. also this was the first thing I have done to the car in ages.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Looks good.My car is a Vazondissan. Part Nissan. Part Mazda. Part Ford. Part VW. Part Honda.
thanks for the info. now i know what i have to do with my steering wheel---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Why don't you modify or use cruise Buttons from that steering wheel, OK, cancel has no use.
If i remember right, BG cruise button is only 2 different resistance value.My mazdaz
mazda 323 BG Sedan GT V6, V6 sound
And mazda 323 BF "GT" FE3, FE3n sound
And all so mazda protége
Originally posted by Chultz View Posthey man.. just read through your thread.. AMAZING WORK so far!!!!!! really impressed!!!! when the next bit of work gonna be done???Last edited by progt91; 10-20-2014, 09:29 PM.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Hopefully soon. Seems like a broken record. Can't find time. When I do have time I have no money. Good news is the house heat has been converted and working great. Saving me some cash per month as well91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by progt91 View PostHopefully soon. Seems like a broken record. Can't find time. When I do have time I have no money. Good news is the house heat has been converted and working great. Saving me some cash per month as well
I was kind of the same boat, between work, family and workout routines had no time so the project had to go. And I kind of lost the passion for it, found my new vein on trxs...
Originally posted by mazpr View PostGood to know you got your priorities straight.
Oh I still have the passion. I'm seriously trying not to give up. Putting up a good fight. But now I'm adding a wedding to the mix of the daily life. Now I seriously have no money haha!91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Time for an update........... **** all has been done since the steering wheel. Took it for a rip down the street. That's about it91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
