klze swap
Did a little work today, started tearing aparts the parts car and also got a little done on the protege91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by stylingtwagon View Postsweet man id spray mine again but i need a reg on my compressor last time i shot primer at 120 psi .91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
lookin good man! i can't wait to find another BG to have fun with!-Jack
please if you have that pop up glass roof piece from the MX3 save it & get me the dimensions of it. mine busted & that looks pretty close---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
that i dont have, i dont know if they are any different than the pro glass roof or not. if they are the same i can give you a measurement. the mx-3 i have had an aftermarket sunroof91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
oh and the glass broke on my today when it was placed on the floor, lol you couldnt have asked me this before91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
didn't know. either way, please take a picture of how it was mounted in. the front tabs & the rear tabs, theres a huge chance they have the same mounting. (which i need as well as the glass panel) i need something bad tho. the only car can't be driven in the rain.... that sucks
If you still have all the mounting bits ( even if the glass is broke..... please please please pic me & save them)---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Postdidn't know. either way, please take a picture of how it was mounted in. the front tabs & the rear tabs, theres a huge chance they have the same mounting. (which i need as well as the glass panel) i need something bad tho. the only car can't be driven in the rain.... that sucks
If you still have all the mounting bits ( even if the glass is broke..... please please please pic me & save them)91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
did some more work on the car today, repaired my cheap wooden engine stand for the kl, much easier to move around until it installed. prepping the engine bay for the v6, pass side mount, swapping over the power steering lines and keeping the a/c intact. tomorrow i will fiddle some more with it. maybe even test fit it in the bay.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
well got some more work done today, installed the mx-3 lcas, rack and pinion, mx-3 sway bar, cleaned and painted the power steering lines, and test fit the kl in the bay to see where i stand in the cooling department. a/c compressor needs to be replaced with a v6 one and also a couple of lines. the protege a/c lines can work with a little tweaking but the compressor has a different bolt up pattern. anyways some time this week the kl is coming out again so i can paint the engine bay, then in she goes for good.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
well guys, a little update. the engine bay is taking longer than i expected due to work but i did manage to pick up a very fresh looking a/c compressor and the lines from an mx-3 v6, they look almost identical to the pro comp but like i posted above the bolt pattern to the a/c bracket is slightly different. upon closer review i might have to tweak the pro line that goes from the comp to the condensor. i just dont see how the mx-3 line will work without doing anything major. i bent that line carefully while it was bolted to the compressor and i think its going to work. will have to post up some pics91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
